Ammonite
Having removed the heat exchanger rubber end caps I had to remove the H/E temperature sender as it was fouling on the tube stack (not the tubes themselves but the circular copper supports that maintain the tube spacing) Is this normal? Its as if the sender is too long. Also with the sender installed you can't centralise the tube stack as the sender is exactly where one of the copper supports sits. Its out by about 5mm which seems odd given the rubber end caps are the same on both ends and results in a very marginal seal between fresh and salt water on the input end.
The sender looks original as it was a pig to remove and is painted green but I guess someone could have painted it by hand.
The copper supports dont have any slots in them that would clear the sender when rotated in a particular position so Im a bit confused. What am I missing?
It's an isolated two wire sender but when i searched for a replacement on parts4engines they only list a switch i.e. one for a buzzer rather than a temperature guage but this does appear to be a few mm shorter and I would expect it to clear the stack however at this stage im unsure which temperature sensor (the engine one or the H/E) supplies the gauge in the cockpit)
Thoughts?
Thoughts?
