Iain C
When I'm finally allowed to go sailing properly, I need to service my 2004 Volvo MD2020 with saildrive on my Bavaria 32. I want to make sure I have everything I need to hand, so I'd welcome any tips. I've also got a few questions raised by the Volvo service manual. So the jobs list I have plus tools is as follows:
Is there anything else I've forgotten, or any other specific tools that I'll need? Many thanks in advance!
- Remove Old Oil-Sealey oil extractor pump, rags, gloves
- Replace Oil Filter-filter wrench (any tips on the best one to use and don't say a screwdriver and hammer!)
- Refill Oil 15w/40-Lucas oil
- Replace Water Separator Filter (Racor or CAV)-standard tools, socket set etc
- New Fuel Filter-filter wrench
- New Belt-spanners, socket set
- Check Clean Air Filter-only recently changes anyway
- Replace Impeller-standard tools, BUT I have a speed seal cover, anything I need to consider?
- Check coolant-Volvo glycol antifreeze if needed
- Check throttle cable / linkages and Idle for correct operation-WD40/GT85
- Change S-drive oil-can this be extracted with the extractor pump with the boat in the water, or do I need to dry out and drain from the leg?
- "Reverse Gear"-the Volvo manual talks about changing the reverse gear oil, but it's not clear if this is not a feature on the MD2020, and is only on the MD2010 and MD2030. Can someone clarify this?
- S-drive anode-obviously this is a dry out job, but I need allen keys, loctite thread lock, prop puller (it's fixed not folding). Is there anything else?
- Glowplugs-the engine isn't great at cold starting, and an ex-Volvo engineer friend saw it and suggested new glowplugs could work miracles as the existing ones are likely to be the 16 year old originals, and they are cheap at £9 each. Anything specific I need to change them? outside normal sockets and standard tools?
