Ric
The alternator on my 2001/1700hour VP MD2020 seems to have failed - when I start the engine there is no change on battery voltage and no charging current (as measured by my NASA battery monitor) whereas normally it would be showing 13.8v and a positive charge. The alternator alarm starts after a few seconds but if I increase revs to around 1800rpm it is silenced (even though there is no change in battery voltage and still no charging). My inkling is that it the alternator is dead but before I go down that route is there anything else I should check?
I do have a Sterling regulator fitted but when I disconnected the white wire (which disconnects the Sterling and reverts to the alternators own regulator) there was no change in the symptoms.
