Kurrawong_Kid
Our "new to us" boat has an MD17D engine which runs well, but it is very difficult to "find" neutral. When cold neutral is correctly adjusted, but when hot is to be found a short way towards reverse-just past the detente. It is remarkably easy to go direct to reverse before finally finding "the magic spot"! I am going to make an attempt at readjustment of the cable to take account of the hot position but unfortunately cannot do this without removing the fine oil filter so this could be a longwinded process. There is not enough cable left to adjust at the wheel - it will have to be at the yoke end. Has anyone else had this problem? And did you find a solution? Thanks /forums/images/graemlins/frown.gif
