simon_34
Hi I just thought I would let you know how I am getting on with my old engine.
Last weekend I found a two small holes in the inspection plate which might go some way to explain why I am loosing lots of oil. The holes are only about a matchstick diameter and a needle respectively.
I thought i could get a replacement cover but spent the week finding out that they are not made and in are not easy to find second hand.
Undeterred i decided to spend today removing the plate for a possible braising repair. However after 6 hours i only managed 3 of the 6 bolts as the allen bolts are totally corroded and I really can't get them out. (I used about 3 different mole grips and even tried cutting a slot in the bolt to use a screwdriver). My only option now is trying one of those little wrenches that grip as you turn, however the bolt is recessed but I will look into buying one this week!
In despair I used two self tapping screw and screwed them into the holes hoping that will sort it out for a bit so at least I can go sailing and i can check where else it is leaking.
Any advice would be appreciated
cheers
cheers
