nunners
New Member
Hi All,
I'm a newby so here it goes...
Ive got the Volvo MD2020 (with prop shaft) that overheats. Raw water intake works, no blockages. Fresh water cooled with expansion tank. Drained most of green coolant out through exchanger cap & Opened front of heat exchanger. (couldn't open bottom fresh water plug without right tool, but drained completely 12 mths ago).
Revealed a tiny bit of sea weed and two of the heat exchange pipes blocked. Stuck needle into pipes to clear those blocked - Cleaned up, checked for scaling (looks good) and put back together. Maybe should have opened other side of exchanger and pushed through a steel stick to clean completely & possibly flush??
Still overheats after 1 hours running at 3/4 rpm. Prop clean & raw water intake clear.
1) How do you remove the inner heat exchanger tubes and give an acid bath without removing the heat exchanger???
2)Does the cap on the end of all those h/exchanger pipes come off for cleaning?? easy to put back?
Pumping plenty of water & possibly steam too. Noticed water in bilge after running for an hour. Checked pipes r/w intake and all look good. Stern gland ok.
Thanks for any advice. . .
Cheers, /forums/images/graemlins/confused.gif
J.
J.
