Volvo MD 2010 oil change
LeonF
25 Jun 2001
South London
Chaninging the oil on my previous boat that had a Beta was a doddle as the pump was on the front etc. Any one with the above who can advise me on the best way to change the oil ? There is a drain hole buried away which I have been told needs a 10mm tube to be fitted over then pumped out..or can i pump out throuhg the dipstick hole?? The boat is canoe sterned so there isn't much room down there. Thanks.
On my 2020 there is a pump-out pipe that is located at the front of the engine close to the sump flange. Thjere is a rubber cap over the end which you remove and then attach the pipe to your pump; or you can use the dip stick hole. I have used both methods and I imagine your 2010 is similar.
Alan.
The lower tube with the cap is the pump out tube as it goes to the bottom of the sump whereas the dipstick tube doesn't.
