Volvo MD 11C - Thermostat equivalents ??
Prices for thermostats are OUCH !! Volvo want over 30 quid for it and then add another 30 quid for postage !!!!! Thats local UK !! Any other sources for thermostat suitable for a Volvo MD 11C ???? part nbr : 876080
johna
12 Aug 2001
Poole
Hi
Not sure about Volvo but I contacted the manufacturer direct for my fresh water cooling thermostat. See my post under cooling systems on the www.yanmarhelp.comforum
norseman
22 Oct 2002
UK
Hi
On the one I bought for my MD11C from MMS a while ago ( now Nauticalia or something ) it said Motorad on it and 60, which I assume refers to the opening temp. By the looks of it I reckon you could buy the same in Halfords or any motor spares shop.
Stemar
12 Sep 2001
The problem with car thermostats is that they open at a higher temperature than raw water thermostats - typically around 85 - 90 (from memory). I suspect the 60 marked on yours is the opening temperature. You won't find a 60degree thermostat in Halfords, unfortunately.
Have you tried Keypart in Watford? Their prices are usually quite a bit less extortionate than Volvo
428, Whippendell Rd, Watford, Hertfordshire WD18 7PT
Tel: 01923 330570
Johnjo
8 Sep 2002
The thermostat on this engine as it opens to let cooling water around the engine shuts off the bypass on the end of the manifold where the thermostat is located. you should notice it is a lot deeper in depth than a car type thermostat.
If you fit a car type thermostat it would not have this function so most of the cooling water would still bypass the engine.
The 60 is the opening temperature as the engine is raw water cooled.
norseman
22 Oct 2002
UK
The bypass hole is only 4m/m presumably to stop the raw water pump dead ending before the thermostat opens. Most of the water still goes to the engine.
