volvo filters
cagey
6 May 2004
Cornwall
Does any one know the motor trade equivalent replacement numbers for oil and fuel filters on a 2003
thanks
keith
Cantata
1 Aug 2003
Swale/Medway
Cagey, if you take the Volvo part numbers into any good motor factors they will be able to look up the equivalent numbers for sensibly-priced filters that they will have in stock.
Stemar
12 Sep 2001
Original PNs:
Oil filter 834337-8
Fuel Filter 840532-6
Nowhere near my boat, so I can't tell you the number, but Halfords do an oil filter. It was the only one the same size and shape.
I didn't see one for the fuel filter, but at a tenner a go, I'm VERY interested in finding a sensibly priced one. A quick Google came up with a Fram equivalent - P4102, but no on-line suppliers or prices.
live near Saint Ives, Cornwall.
www.celticwebdesign.net
This is for oil filter, though fuel filter reference will also be found.
Volvo Penta's part site http://accessorycatalogue.penta.volvo.se/catalogue.asp shows the following engines take the same oil filter
Pos no. 17.1
Part no. 834337
Engines/Drives 2001, 2001B, 2002, 2002B, 2003, 2003B, 2003T, 2003TB,
AQD2B, MD11C, MD11D, MD17C, MD17D, MD1B, MD2,MD2B, MD3B, MD5A,
MD5B, MD5C, MD6A, MD6B, MD7A, MD7B
Knecht filters - OC 11 oil filter for the Volvo engine
www.berlyn-services.co.uk make enquiry.
Look at http://www.filtrauto.com/ccatuk.html
Marque : Volvo
First three letters filter reference : 834
Oil filter - 17.2
Reference 834337
Crosland 659
Fuel filter -
References 829913
Crosland 5003
or
References 8614760
Crosland 2067
That's the best I can do, but have a look to ensure yourself.
RivalRedwing
9 Nov 2004
Rochester, UK, boat in SYH
Be very careful with fuel filters - some third party filters are cheaper because they contain less filter packing. If one assumes that the filter packing is the same grade as that used by the original supplier then the third party one will block more quickly (less surface area), if it is a poorer grade to avoid rapid blockage then bigger bits will get through - the filter is there to protect the pump and injectors from crud - at one or two filters per season even the original fuel filters are cheap in comparison to a set of injectors (£100?) or a pump rebuild (£400?). I learnt my lesson when using cheaper alternatives to a Delphi / Lucas 296 filter to save a couple of £, now I will not fit anything else (but buy from a Delphi motor dealer).
