LeonF
Having ascertained that it isn't the water pump leaking raw water into the bilge, I have discovered that it's coming from the overflow pipe attached to the freshwater coolant tank cap. At high revs water is pouring from this pipe. At first thinking I must have linked the systems inadvertently I realised that is not so as the exhaust is working fine, and the coolant tank water stays constant. Could sommething have corroded allowing the saltwater to enter the fresh water cooling system ?? It has been suggested that the O rings on the heat exchanger may have perished. Any other suggestions please?? Oh it's a 2010..
