mldpt
Hi here we go again, my 2003 V/P has now been rebuilt, 4000 hours on the clock, Original problem, poor starting and excessive smoke, Had injectors serviced £180 cured the smoking but still poor starting, had head off exhaust valves badly burnt and seats pitted, had valves and seats re cut and lapped in, compression much better, and starts a bit easier, but now excessive unburnt fuel from exhaust. Had engine out bores honed new set of rings and bigend shells, old ones worn through to copper. I have been told that this is due to fuel getting past rings and into oil. its now rebuilt and has done 30 hours approx. She starts instantly, has loads more power, and revs to 2800 rpm which it never did before in 10 years, sounds wonderful, infact I am very pleased with it except for the smoke from the exhaust, at first I though it might need bedding in and I convinced myself it was getting better, but it is now leaving a far worse oily mess on the transom than before, I am sure it is unburnt fuel, as there is black sooty deposit in the water, could it be the Injectors if not what else could it be. The engine does'nt seem to use any oil now its bedded in. I will have the injectors checked again next week but has anybody any ideas.
Mike www.sailiingforfun.co.uk
