kghowe
Can you help me determine which props I should have on my boat. I've got to replace both pairs due to damage and corrosion.
First the good news, both props are A6's. However both the foward props have different VP part numbers. Port side fwd prop is 15mm dia larger than rear where as the stb fwd prop is roughly the same size as the rear one. Which is right? From memory my Targa had one large on the front and small at the rear (prop nut end). Part numbers are 854779 (Port) and 852251 on stb. Engines are AD41's. Incidently both engines seem fine and can pull 3500-3600 rev's.
Any ideas out there? How do you size a prop anyway? Surely its not down to suck it and see.
Kevin
SBS
Kevin
SBS
