cpedw
The engine is a VP 2003, fresh water cooled. The problem is a slow leak (drip) from one of the raw water connections to the heat exchanger. The sealing arrangement seems very Heath-Robinson but it has worked for several years (and presumably for many years before I owned it).
Any suggestions for making a reliable joint here? There's going to be fun sealing the end caps back onto the heat exchanger I expect, as they and the seawater pipes are all held in place by one long threaded rod as far as I can see.
All advice gratefully received before I turn a minor drama into a crisis.
Derek
Derek
