mil1194
I have two B20 engines - I believe they are 2litre engines and need completely rebuilding. They are coming out of a boat and have been completely neglected for around 5years. I would like to keep these engines as they have only done around 70hrs from new and have water cooled jackets (exhaust manifolds) and tie in nicely with the Volvo Legs (Z-Drives) for cooling (270's). The only changes I have considered have been to remove points/distributor etc and replace with electronic ignition is this is straightforward enough - cost not necessarily an issue if it will simply day to day use!) and also considered from a distance fitting fuel injection as long as this isn't a nightmare of a job.... ANY info/suggestions gratefully accepted. Many thanks in advance!
The OTHER option is to take these engines out and change the system completely, but I would be reluctant to go the very slow (5/6/7knots) route with a couple of old diesels!
