jamesm
New Member
Hi.
I'm after some advice about an overheating problem.
I recently had a rush of blood to the head (against my wife's better judgement) and bought a Princess 32 with twin Volvo Penta AQD21 diesels with Volvo 270 outdrives. The starboard engine has always ran a little warmer than the port engine, but not overly so. However, the other day, the temperature gauge rose until the needle just about hit the red. I ran the engine at idle and the temperature dropped to normal. After replacing the raw water pump impeller, the problem appeared to be resolved and I was able to pacify my wife with my ability to maintain old engines, restoring her faith in my rash purchase.
However, after about an hours cruising the next morning, the temperature on the same engine crept back up in to the red. I used my last remaining spare impeller, but it made absolutely no difference, the temperature increased and rose almost to the red even with the engine idling with no load.
Can anyone suggest a solution, please?
By the way: the boat has only been used on inland waterways for many years, the previous owner had the heat exchangers re-conditioned two years ago and the boat has seen little use since then.
Thank you.
Thank you.
