Volvo AD41 Filters - again :)
robrennie
Active Member
7 Jun 2017
Glastonbury / Port Solent
Hi there,
I managed to get the time to do a test on the AD41, filters and smoking.
1, Fitted new Volvo filters, very little change in smoke from old.
2, Started port engine without filters - virtually no smoke.
3, Performance at sea was identical for both engines.
I don't like the idea of running without filters so am going to fit K&N's. My boat is a couple of hours away and I would like to order the filters before I go down.
Does anyone know the diameter of the Turbo Inlet so I can order the correct ones.
Thanks in advance.
For reference, previous post on subject:
http://www.ybw.com/forums/showthrea...r-Volvo-AD41&p=6513848&highlight=#post6513848
In case anyone searches on this topic.
Diameter of the flange is 70mm.
K&N part number for the largest filter that will fit is: RU- 0940.
Just ordered them, will fit them within a couple of weeks of them arriving and will report back in case it is of use to anyone.
I fitted the same or at least very similar to my TAMD60c - no problems. I use 3in1 spray oil instead of K&Ns branded priming oil. I wouldn't use WD40 as it mostly evaporates.
