Freeloader
Unfortunately, I can't provide much technical information here as the offending article is not my boat! However, the motor (a Volvo 5.0L 270hp V8) is fitted to a Rinker 246 (I think of circa 2008 vintage) and has the duo-prop sterndrive. Whilst the motor will apparently start perfectly well on the flush muffs, when put in the water (the boat is on a dry stack) it simply will not start. Two separate marine engineering firms have played about with it and changed one or two parts but said that they can otherwise find nothing wrong with it - (on land) it starts and runs fine.
Indeed, subsequently it was started on the muffs and then dropped into the water but then failed to start. However, when lifted and held just above the water by the fork-lift, it started and when dropped back into the water (still running), it ran around fine for a couple of hours (without stopping the engine). The engineers from both firms and the owner are at a loss to know what to try next. Could there be some sort of grounding issue when the boat is put into salt water???
Any advice or suggestions would be gratefully received!
N.B. We are keen to sort this out, not least because we are supposed to be meeting up with our respective boats and families next week...
