PooleAndy
Does anyone else have experience with recurring oil leaks from the oil sump of VP's 4.3 GXi-F engine?
The oil seems to be weeping from the front end of the sump, near the crankshaft (an area of the sump with fewer pull-down bolts!). The sump and block have been checked for scoring and distortion with no evidence to suggest a problem.
New sump gaskets and crankshaft seals have been installed and it's run for hours on the bench, again with no problems. But after a few hours of normal running the problem reappears. The engine has been out of the boat 3 times now (soon to be 4!) in an attempt to keep the oil where it matters.
The marina where the boat is kept have provided a sterling service, including engaging the input from the Poole area VP main dealer, but so far all attempts have failed.
Accepting that the issue needs to be fixed, again, can anyone on the Forum recommend a VP specialist in the Weymouth to Portsmouth region. who may have the knowledge and/or magic sealant to fix this problem?
Thanks in anticipation.
