jimmy_the_builder
Evening all
I've got an odd corrosion problem on one of my outdrives: the port outdrive casing is corroding quite badly; the starboard casing is fine. Both transom shields are fine.
The boat is out of the water at the moment and so the engineer went over both drives with a multimeter. One marked difference is that the resistance between the yoke and the helmet on the corroded drive is about 40 ohms; on the good drive it's close to zero.
Anyone got any idea on why this should be? My feeling is that resolving the electrical differences between the drives should in turn help us solve the corrosion problem.
Jimmy
Jimmy
