john0740
Today I discovered a missing impeller blade, and on advice removed the rubber muff on the sea water input end of the heat exchanger to retrieve the blade. I was rather surprised to find that when the rubber muff was removed, that engine coolant came out! I'm told that this is normal, but is this correct?
I looked at the service manual, and it appears from the picture there that the rubber muff holds in place the heat exchanger "insert", and so perhaps the coolant comes out of the small gap around the insert where is slots into the heat exchanger?
Any advice appreciated.
