grafozz
i had a valve job done on my MD 2010 last year after water ingress had damaged the valves ,fitted all new and engine ran fine for 3 months . just started it ready for launching and found it hard to start after removing injectors i found water was coming out of both cylinders ! i have now stripped off head and found rusty valves again . where is this water coming from ? ?it is cooling/fresh water as there are white deposits on tops of pistons indicating coolant /glycol have looked closely for any cracks , is the head most likely source of leaks? please help cant go sailing !¬!"!
