skipper021
This winter’s project is to change all 4 engine mounts as I got a rope around the prop just before coming ashore in November. The rubber on the aft mounts partially detached from the metal part of the mount so at least the aft ones would need changing, but I am thinking of replacing all 4 as they are around 20 years old.
The standard VP mounts which were fitted are different types fore and aft on the MD2010, the engines are supplied with part nr 861460 at the front and 838262 at the rear.
Anyway, I removed both aft mounts today, and ran into a problem. Each mount is bolted onto the engine beds with two coach bolts of unknown material, probably not very good material as 3 of them sheared off!
Now, I am considering replacing these engine mounts with Silent Marine AV Mounts, rather than like for like VP mounts. Here are details of the Silent Marine AV Mounts: (Marine Engine Mounts: AV Mounts Online) which would cost about £124 for all four including height adjuster bolts.
The mounting base of the Silent Marine mounts are 100mm between centers so I would need to drill new holes into the engine beds, which are grp covered wood as far as I am aware. This would neatly sidestep the sheared off bolt holes as the new holes would be inside the foot print of the old VP mounts which have a hole centre of 125mm.
In principle, does anyone see any particular reason not to do this?
