Cspirit
I have just taken this apart in order to remove the impeller blades that were shed from the seawater pump (don't ask). However, when I (eventually) got it back together, with no leaks, I now have a new problem in that the engine overheat alarm starts to buzz after about 20 minutes or so running at 2,000 revs. Slowing to about 1700 revs shuts off the alarm. I did not have this problem before I removed and took apart the heat exchanger, so I'm wondering if I have reassembled it incorrectly. Does anyone have a diagram or can assist in determining the correct orientation of the end cap? Of course, the problem many lie elsewhere - perhaps a blockage somewhere in the cooling system, fresh or sea water. It's not the thermostat (replaced) or the seawater pump (brand new). Any suggestions gratefully received. Bob
