Volvo 2003 and black smoke
My freshly painted transom is covered in black diesel smoke/stain after only one week. What could be the cause? The Volvo 2003 is running well.
jfkal
17 Aug 2001
Singapore
Could be overload by a wrongly sized propeller or a fouled propeller inducing to much load. Is it smoking black also out of gear if you rev up? Could be clogged injector nozzles then
tubba
24 Feb 2002
East Yorkshire
Two out of three answers are correct,Dont know
S######n, ?
Try the air filter first,Check timming,running temp, All cheap Then I`ll take your money to calibrate your injector`s
beneteau_305_553
1 Apr 2002
Norfolk UK
I have a volvo 2002 and used a can of injector cleaner in a teankfull of diesel and the exhust is now completely clear. Its costs about £8 which is much cheaper than servicing the injectors to achieve the same thing.
Treat the deisel with biocide regularly and the injector cleaner once a year.
use starbright hull cleaner to remove the stains. It works brilliantly
Richard
