Volvo 2003 again
PeteB
26 Jun 2001
Can someone tell me the revs a Volvo 2003 should be run at.
I've been told 2200rpm continuous, 2600rpm for up to one hour.
Sounds low to me - can anyone confirm?
Hi,
Volvo 2003 is rated at 28 HP at 3200 rpm max on load. This power is recommended only for 1 hour continuous in 24. For extended high power running use approx 200 to 400 rpm less than max, so 2600 would be a good speed for the engine. This may not be a good speed for the boat / hull speed / weather conditions etc. only you can tell.
Hope this helps.
Springer.
sapper
2 Nov 2001
Chepstow
I did reply to your enquiry about 2 weeks ago and cant understand whats gone wrong as there is no sign of my message. Here goes again, I have a workshop manual for a 2003, if you would like a copy (they arent that big), please confirm.
JamesS
12 Oct 2001
Recommendations from the manual aside, I guess it depends upon your boat and conditions and to a certain extent how much fuel you wish to preserve.
Our Moody 31 is able to maintain 6kts in a smooth to slight sea at 2000 rpm - in fact we seldom go above that. When this figure starts to deteriorate - time to antifoul!
Beyond that point improved performance is marginal and the fuel consumption soars.
Cheers
andy_wilson
S. Yorkshire / Devon
Bukh
Anyone can build an overengineered and under performing motor.
I takes a bit more thought to come up with something that can provide a higher specific performance, even in short bursts.
Personally I find most Bukh engines and parts over priced and the engine particularly over sized and over weight.
Take a Bukh?
Keep it!
marcelo
19 Jul 2002
italy genoa gulf
Hi,
I have a 2003 (turbodiesel 45hp, the former owner thought that he could get more power at more or less same weight than 28hp – is a 37sailboat may be overpowered? ) I’m interested in the manual, can you put it into pdf or other form or format transmissible by e-mail?.
I’m also interested to know which are the cruising revs.
Marcelo
mldpt
Fleetwood
I run my 2003 at 2500 rpm for general cruising, on my 36 ft Sloop weighs 7tons does about 6.5 kts depending on the sea state, uses about half a gallon an hour, has done 4000 hrs since new in 1988. will rev to 3000 but the speed increase is hardly worth it.
Mike
