Volvo 2002 water leak – help please.
SlowBoat2
8 Apr 2004
Thought that the impellor unit had developed a leak. Closer inspection shows that it is the part that the impellor unit is bolted onto thats leaking (?). Can I take this apart and fix it myself? Is it likely to be a gasket that needs replacing.
Any tips/hints/suggestions gratefully received.
BigART
11 Nov 2003
If I remember correctly from my last boat fitted with a 2002 (have you had your drive hexed?) there is a little slit behind to water pump housing which is intended to allow water to escape should the pump bearing seals start to leak. If the slit was not there, the water would escape into the sump causing all sorts of problems. The bearing seals are fairly easy to change I seem to remember. I think a kit is available.
HTH
<hr width=100% size=1><A target="_blank" HREF=http://www.DoItCruise.info>http://www.DoItCruise.info</A>
frilaens
12 Jul 2002
Norway
Yes, there is a kit. I have done this job on my 2001 and it was OK.
<hr width=100% size=1>"Borders? I have never seen one, but have heard they exist in the minds of some people”
Heyerdahl
Piere
17 Jul 2004
kent uk
Got same problem with 2001 impeller housing
let me know how you get on
only a very small drip
I will do my own research at local volvo dealerand report back
Juggler7823
UK, North Wales
Bigart below mentions the tell tale hole which shows that the oil/water seals are worn. A kit is available from Keypart/Volvo etc. Remember that the seals go back to back ie not facing the same way. Some diagrams show a thin O ring. This is not now used. Its a simple job but remember to grease the seals as you put them in or you will turn them inside out. Also grease the tip of the shaft as you press it into the seals
<hr width=100% size=1>LOM
