flyingscampi
The alternator pivot bolt worked loose dropping the alternator onto the oil pressure sender, breaking it and causing an oil pressure warning.
I bought a replacement oil pressure sender but when I attempted to remove the old sender, the back of the casting (that the sender screws into) broke off in two pieces.
After breaking open the emergency tobacco ration, I discovered that the broken part is a 'Timing Gear Casing' (Part: 860546) and a new one matches Tamara Ecclestone's annual shoe budget.
I'm just wondering what my options are? If I remove the casing, can it be repaired? Or maybe a new mounting could be attached to the original casing?
Is there a good source for someone who could supply a used casing?
The engine is in good condition for it's age so I don't really want to consider changing it.
Thanks for any help.
