SABREMAN
Active Member
I have an `Hours run` counter fitted to the boat which has never been connected ( the terminals have no scratch marks on them) and having bench tested it to check it works I would now like to connect it to the engine to be a bit more than just a useless ornament. Question is, how?
The standard wiring diagram from the Volvo workshop manual shows three items at the bottom of the diagram which I assume to be, from the left, the battery master switch, the starter motor and the alternator. Would it work if I connect to the B+ and B- on the back of the alternator and therefore only run when the engine is running, as it should, or am I missing something?
Any help would be much appreciated.
