volvo 2002 hose size
saltyrob
11 Apr 2004
Suffolk
Hi
Could you tell me the diameter of the hose which connects the raw water inlet strainer to the gearbox cooling water inlet. ( Volvo 2002 18 hp).
Many thanks
Saltyrob
philip_stevens
live near Saint Ives, Cornwall.
www.celticwebdesign.net
Have a look at http://www.boten.nl/motoren/motoren_pdf/volvo_penta_2002_owner.pdf
You may find the information you need is in one of these manuals.
There is also a third manual, <A target="_blank" HREF=http://www.boten.nl/motoren/motoren_pdf/volvo_penta_2002_oper.pdf>http://www.boten.nl/motoren/motoren_pdf/volvo_penta_2002_oper.pdf</A>, that may be of help to you.
<hr width=100% size=1>regards,
Philip
Will_M
26 Jul 2001
GBR
Internal diameter of 16.00mm
(in actual fact the hose from VP is 15.90mm internal diameter)
DaveS
25 Aug 2004
West Coast of Scotland
I needed some 16 mm hoze last year when I fitted an inlet strainer to my VP 2002. I ended up buying a 30m roll of the stuff! Its transparent, reinforced type and has worked well on my boat. Even after finding other uses for some of it I still have far more left than I'm likely to ever need. I'd be more than happy to supply modest quantities to anyone reimbursing me for p & p. PM me if interested.
