Volvo 140 hp manuals?
cngarrod
29 Nov 2002
Ipswich, UK
Anyone got any ideas where i can get my hands on a manual for a 23 year old engine... volvo penta 140 hp petrol... can't find the model number on the engine, so not totally sure what it is!
TIA
Craig.
Have a look in Halfords. I think this is the 2.3 litre four cylinder petrol engine. If so, it is basically the same engine as went in the 240 series Volvo cars (tanks!). You will also find that Halfords are a good place to source plugs, points and oil filters. The major difference is in the cooling system where you have a heat exchanger arrangement as opposed to the radiator found in a car. Otherwise there is little difference.
Nick
The engine is a 2.1 litre B21, the same engine is (as nick says) fitted to the Volvo 240 car.
You can get a manual specifically for the Penta engine from Keyparts in Watford (£20 ish). I've just replaced a dead engine with one from a car and they're almost (but not quite) the same. If you need any more info get in touch.
RobG
I had a Fairline Mirage with twin AQ125's. Those were 2.1 litre. The AQ145 (son of the 140?) I was sure was a 2.3 engine. I'm going back a long way so may be I'm wrong
Nick
despooner
20 Jul 2001
Kent, England
Craig,
I have found an old book in my boat with the same engine titled
'Do-it-yourself-Aquamatic' by Volvo Penta, Publication nr:7730252-9.....10-1985
All the pages are stuck together so it's not much good.
It came from John Hawkins Marine at Rochester Tel:01634 840812 if they are still there.
David.
sonarbell
11 Jun 2001
Midlands
2 options
a/ ISBN 0-89287-638-7
b/ ISBN 0-89330-011-X
Both good, first one is better, both available from any good book store or I ordered both from amazon.co.uk. Both books cover all petrol engines and some diesels from 1968-1993 believe it or not.
Hope its of some use.
Rich_S2
14 Jun 2001
Thames Valley
Used to have an AQ140A four cylinder 2.3 in a birchwood 22. Twin carbs etc. Have a photcopied manual purchased from a service agent that you can have if you want it. If you give me your address I'll pop it in the post.
Regards............Rich.
cngarrod
29 Nov 2002
Ipswich, UK
Bit of a silly question now.. but should i put Unleaded in it or LRP... had been putting unleaded in it.. and suddenly thought at the weekend.. this might not be a good idea!
Will_M
26 Jul 2001
GBR
Leaded or Unleaded...
If indeed you have the AQ145 which was based around a 2310cc unit (B.23) then either the AQ145A or AQ145B require a min fuel octane of 95 (A) or 90 (B) as such unleaded or leaded (LRP) is perfectly correct to use.
If you want one new copy of the DIY Aquamatic manual let us know.
Regs,
Will.
Rich_S2
14 Jun 2001
Thames Valley
used to run mine on unleaded with no additives. It said it was alright to do so on the big black cover that sits over the two flame arrestors...........
cngarrod
29 Nov 2002
Ipswich, UK
Re: Leaded or Unleaded...
The only info i have is that it is a 140 Hp Volvo Penta petrol.. circa 1978... so if it is the engine of which you speak... how would i know if it is the A or B version?
How much is the manual?
Rgds,
C
cngarrod
29 Nov 2002
Ipswich, UK
Hi Rich,
Got the manual - thanks - it is very useful.. bearign in mind i had nothing.. there are some excellent pointers in there to make sure it keeps going!
Craig.
Will_M
26 Jul 2001
GBR
A or B? If you still have the decel stickers on top of the black plastic air box, it will say there, if thats missing does the engine still have its ID plate (gold & black plate) on the side of the block there you will find a serial number from that I can tell you A or B.
The manual, how much? Put a donation into your local R.N.L.I collection box and I will put a copy in the post, email your details to: willmarrs@petersplc.com
Regs...
cngarrod
29 Nov 2002
Ipswich, UK
Thanks Will
Will have a look and let you know.. email winging its way to you now with details!
Craig.
