biasi
New Member
Hi all,
I have a volvo 120S C saildrive on a 12m sailing boat. Recently bought a more recent but used 120S E with the intent to replace the 120S C because I suspect a crack in the gear housing due to corrosion of the sea water inlet resulting in finding oil from the drive on the rubber seal. While rebuilding the unit I noticed that while the 120S C unit's cone clutch is all brass even at the contact point with the gear drive surface where it is also grooved for oil drainage, the 120 S E clutch seems to be coated with what i am thinking is a friction coating at the contact point of the clutch with the driven gear on both the forward and reverse sides of the clutch. This would explain why volvo changed to synthetic GL5 gear oil for this model instead of the 10/40 engine oil of the SC
However part numbers on both clutches are the same.
The unit seems to operate fine though I cannot simulate the same working loads it would have installed on the boat while testing on the bench.
Can anyone confirm whether this is how the clutch is supposed to be?
Appreciate any information you can provide.
