Voltmeter
JohnL
29 Jun 2001
Northumberland
Help please,I intend to fit a voltmeter to my boat, problem is there are three terminals two are spade type marked +/- which give a reading on the meter OK but there is a post termial marked S, can anyone tell me what this is for. There are also two obvious leads for the light, thanks in advance.
Rich_F
25 Sep 2002
Edinburgh
Can't help directly, I'm afraid, but I do have a related question.
I'm wanting to fit a digital voltmeter to my boat, and want to know if anyone knows where I can get a cheap one. I'm finding it irritating that digital multimeters can be got at very low prices, but a dedicated panel-fitted voltmeter costs upwards of £50.
And while I'm here... I also thought that it would be useful to fit an electric water tank gauge. Any cheap solutions for this? I'd have thought that a water pressure transducer fitted in the outlet pipe would be the simplest solution, but the commercial offerings seem to involve floats, etc, and are around £100 for a complete solution.
Thanks,
Rich
Gunfleet
1 Jan 2002
Orwell
Why don't you just use the digital handheld? You have to wait half an hour after charging or discharging for an accurate reading, but it will give you a very accurate picture of your battery's condition.
duncan
Home mid Kent - Boat @ Poole
Many of your electronics could already have one for you - both my sonar units enable we to show volts in a seperate window or overlayed on screen if I require as does one chartplotter.
oldsaltoz
4 Jul 2001
Australia, East coast.
G'day JohnL,
You say there are 2 more wires for the light, is this an instrument or warning light?
If it's an instrument light the remaining wire may well be a 'S' signal light, If you have a multi meter, try connecting a 12 volt globe and your meter between it and earth to what sort of voltage is running thru'.
Hope this helps
<hr width=100% size=1>Andavagoodweekend, Old Salt Oz /forums/images/icons/cool.gif
philwebb
8 May 2002
london
Hi John,
Does your voltmeter give an accurate reading when you use just the two spade
terminals? If so you can probably disregard the other terminal . The S may stand for
shunt - actually a series resistor on a voltmeter, which might be used to give the
voltmeter an extra range eg 0-50 volts instead of 0-20 volts. A moving coil voltmeter
(with a needle) is really an instrument measuring a small current. With the addition of a large series resistor it can be calibrated to measure voltage.
Regards,
Phil
PS RichF-have you tried MAPLIN-they do cheap electronic components.
Rich_F
25 Sep 2002
Edinburgh
Thanks - good point. I've just acquired a fishfinder with voltage display, so I can use that.
But in addition, while I'm rewiring the panel, I think that I'll add a chocolate-block of test points for measuring various voltages in the system from one convenient location.
Cheers,
Rich
Evadne
27 Feb 2003
Hampshire, UK
It could be a shunt az Oz suggests or possibly a screen (i.e. ground) which you would connect if the wires needed screening. Sometimes you can find deails on a manufacturers website of quite obscure instruments.
pete
Here
Hi
I also wanted to fit a digital volt meter to my boat but was put off by the price I got one in the end from RS, it measures about 30mmx20mm and cost around £30 inc p&p.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Re: Multimeter
Your local cheapy hardware shop (Anything-for-a-pound or the like) will have cheap multimeters, £3.50 to £6.99.
I bought two from Liddles when they has them in @ £3.50, perfectly adequate to leave on the boat.
I can then keep my expensive Fluke at home.
duncan
Re: Multimeter
an answer to a question I have been mulling over! thank you. Having decided not to leave my 'quakity' mm onboard I inevitably didn't have it with me on the last two trips and needed it! It's off to Liddles then.....
pvb
UK East Coast
The S Terminal...
The voltmeter should work fine without using the S terminal.
The most likely explanation for the unnecessary S terminal is to enable more economical manufacturing of the gauge. Most gauges have a sensor connection (hence S) and I'd imagine the manufacturer considered it cheaper to use a common body for all gauges rather than having a dedicated body for the voltmeter.
HaraldS
22 Nov 2001
on board or in Austria
www.taniwani.eu
If it has a metal housing, the S-post might be connected to it and stand for "Screen". In that case you wouldn't really need it, but I had my digital AMP-meter go crazy when I was anchord next to a huge AM radio station. Grounding the screen of the cable that goes to the shunt helped a lot but not completely and I wished mine had a screen to connect.
<hr width=100% size=1><A target="_blank" HREF=http://www.taniwani.de>http://www.taniwani.de</A>
bedouin
As others have said - a cheap digital handheld will cost you about £5 and will do the job perfectly well. The only disadvantage with this is that they require a separate battery - and cannot be run from the boat battery (because they like their internal supply isolated from the supply which they are sensing).
If you want a posher one, capable of being powered by the same supply that it is sensing - then you will have to pay a lot more. RS do a very nice one with two-wire connection - this costs about £25 and is identical to one being sold by marine retailers for > £50
