Ronald_M
Hi all - could I ask for some advice please?
I'm trying to regulate the output voltage of my outboard motor's charge coil. The motor is a 9HP electric-start model fitted with a rectified, but unregulated, battery charging facility rated at 12v/70w. The manufacturers do not supply a voltage regulator for my particular model.
Measuring the charge voltage accross the battery terminals gives a reading in excess of 16 volts - too high for comfort. However, if I connect a 10w bulb accross the terminals, the reading falls to about 13.5 volts/1.5 amps - much better. As a temporary fix this arrangement is OK, but I would like to install something more permanent.
Would some kind of "power resistor" work? Something that will drop the voltage and be able to handle the current? Of course, the resistor would have to be switched out of circuit when starting/switched in when the engine is running, but this should be quite easy to arrange.
Any thoughts?
Cheers,
Ron.
Any thoughts?
Cheers,
Ron.
