Volt/ammeter connections
cindersailor
30 Jan 2003
Edinburgh
Why would engine panel volmeters and ammeters have three terminals? labeled G(ground), L (live) and S (sender?). It would seem to me that only the first two would be required in each case.
Not sure of the make as there is none written on it, but the body is moulded from pale green/blue plastic and has a kind of upward water-spout type symbol moulded in.
Sounds like a very old Whale instrument I believe no longer made, a volt meter usually has 2 connection and if the light is "Inbuilt" 3, like wise for the ammeter, VDU temp guages have three, also the sender has 2 spade connectors Oil and water temp), Thats all the advice that I can offer,
Does the light actually have two wires to it. If not then one of the three presumably the G is connected to the case to provide the second connection to the light, leaving S and L as the connections to the instrument itself.
All the old car type gauges I have do have a single contact bulb with the return via the case< but I have no idea what the S and L might actually stand for.
