Vinyl stripe removal
Appleyard
23 Oct 2004
UK
There was a topic some time ago re renewing the vinyl stripes from the hull and topsides..particularly about removing the old stripes.I recently removed the old stripes from the boat ..used a very sharp wood chisel held at an acute angle ..worked a treat,even removing most of the adhesive .Finished the job off with acetone .Apologies if this method has ben posted before,hope it is of help to somebody.
I use a plumbers gas torch. Carefully heat the vinyl and it releases its grip. It dosen't take much heat. Keep the torch moving.
I use a strip removal tool on cars nearly everyday called a toffee wheel, you put it in a drill & it removes the strips with out marking the paint work, they are avaliable from most car paint suppliers, if you want i can always sort you out a number for somewhere that stocks them
regards
graham
Echo above generally. Heat good - I used a £9.99 Screwfix paint gun that also does heatshrink tube a treat.
To rid adhesive completely, I used Screwfix contractors' solvent and those green supermarket dishscrubby pads - solvent stuff is also excellent at removing contact adhesive from old headlinings etc.
"Sticky Stuff Remover" available from good hardwear shops will remove any adhesive remaining after using a hot air gun to remove the tape.
I should have perhaps mentioned that when I did the job recently I did not have access to power for a hot gun,nor did I have a gas torch at hand ..I was suggesting an alternative method of removal which might be of use to anyone in a similar situation.Also as it is a "cold" method it does not soften the adhesive which means that it does not go gungy and comes off along with the tape more easily,leaving a small residue.The chisel must however be kept razor sharp.
I should have stated that when I just completed the job, I did not have access to electricity for a hot gun, nor did I have a gas torch. I was offering an alternate removal approach that may be useful to others in a similar position. Also, because it is a "cold" technique, the adhesive does not soften, so it does not become gungy and comes off with the tape more readily, leaving a little residue. The chisel, on the other hand, must be kept razor sharp.
