Sailing newbie selsey
Has anyone used vinyl floor planks for flooring in their cabin, if so what adhesive did you use. Thanks
Hi yes sticking to wooden painted floor, will obviously cut the access panel holes for the bilge hatches. They are vinyl planks not rigid like laminate flooring they are very hardwaring and used in commercial settings for flooring, designed to be able to be wet and mopped etcSailing Uma used laminate flooring, not even the nice vinyl stuff. I imagine their floor saw more use at the boat show than any of ours will in a year, and it's also survived basically all of the climates a boat is likely to see.
With adhesives I'd go for the one you'll be happiest cleaning off in 5 years or so. It's on the floor so doesn't need a lot of holding in place and it'll be stiff so unlikely to move sideways easily. I'd even consider a silicone sealant which will be very easy to remove and will last well while also sticking more than enough for the job. something like Evostick if you're paranoid might work well too. I'm assuming you're sticking to normal boat floor boards here?
This is the stuff it comes in planks made from vinyl no wood and semi flexibleAre we talking about the likes of Karndean flooring?
Such as this:
Karndean Knight Tile Lime Washed Oak SM-KP99 Parquet Vinyl Flooring
I think I'd go with contact adhesive to stick them down. You can get it in 2.5l tins. Make sure you havereasonablevery good ventilation in the cabin when using it.
To be fair, I only mentioned laminate because it's less suitable than luxury vinyl flooring and Uma have managed fine with that for many years. I knew what the OP was talking about, I was just countering Stemar's speculation that it might not be suitable, personally I think it's more suitable than the wood and thin veneer that manufacturers use. If the boat is wet enough that any flooring is a problem, up to and including '70's style fluffy fur carpets then the boat or skipper needs fixing rather than the flooring!Everyone else is talking about laminate
I doubt more so than the veneer on production yachts. Uma suggested a sharpie to hide any scratches...so easily scratched and marked
New England 5261 | TLC Luxury Vinyl Tiles | Best at Flooring
