Views on bondage!
gunnarsilins
Stockholm/Sweden
www.eilean.se
Sorry, just wanted to catch some attention!
On my boat, all metal underwater parts, like skin fittings, prop- and rudder shaft etc are bonded together and connected to the engine block (and thus battery negative) and one huge zinc anode.
How should I do with a retro fitted bow thruster and keel cooler for the fridge? Both these items have their metal parts already connected to battery negative through the supply wiring.
Should I double up and have a separate wire connected from these to the anode?
Also, should an external aerial ground plate be connected to this anode as well?
Not sure about the rest, but the ariel ground plate should not be connected to the anode. I don't personally like all my skin fittings connected to the engine (battery) negative, as they could all de-zinc at the same time as the anode, given an electrical leak, I tend to go with the totally insulated method of engine/boat wiring, with only the (insulated) engine, shaft and prop connected to the anode, but there again all my underwater bits are bronze, even the shafts so no de-zincification is possible.
