AngusMcDoon
Looks better watched full screen through YouTube in HD (click the cogwheel & select 720p or above).
Ireland?
Thread drift ..... can you give some details about your solar panels set up, please?
2 Spectraflex 32 Watt flexible amorphous panels into a dual channel charge controller charging 2 75 Ah batteries. No separate engine start battery as the engine is an outboard. Although it's electric start it is also easy to hand start so no dedicated start battery is needed. Engine produces maximum of 10A. Each solar panel 1.8A when aligned in bright sun. Amorphous are less efficient in unshaded bright sun compared to crystalline but better on grey days, & way better when partly shaded. Because I sail in northern latitudes with more grey days amorphous are more suitable. The Spectraflex panels are not cheap unfortunately.
I suspect we passed each other in Loch Fyne the other day. You were running down the Loch towards Skipness. Possibly Monday?
Donald
Your drone video makes it look so much nicer than google managed to. Amazing what some rays of sunshine can achieve!
