Victron Charger Skylla TG 24v 75A
Leaforge
14 Sep 2012
Nantwich - Cheshire
Hello All,
i have a charging fault, battery bank keeps going flat (batteries are ok) will not charge on shore power, i am making the massive assumption that it is the charger. Does anyone know if Victron chargers are repairable / testable etc and if so who is best bet to do repair.
is there a test i can do to check if it is the charger?
Many Thanks
david_bagshaw
5 Jun 2001
uk
mains power to the charger and voltage at the output terminals, ideally 28 + depending on state of charge. Also check inline fuse if fitted on the output side.
Otherwise probably needs hooking up to a lap top with diagnostic software
certainly repairable as skyella is a good bit of kit
