Ben_e_Toe
Just installed a new VHF/DSC set (Navman 7110). Connected it to exisiting internal wiring, then via a deck fitting to new wiring from deck up the mast and finally a new aerial. Problem is that, whilst it receives perfectly, the set won't transmit beyond about 20 meters! Yesterday I took the deck fittings apart and resoldered the joints then Sikaflexed it all together. I have check the plug at the VHF set end and there isn't a short.
Any suggestions as to what to try next? Obvious thing is to shin up the mast and check the connection on the aerial base, but I wouldn't have thought it would receive if that was faulty............
