johnphilip
I had fitted a new masthead VHF aerial over the winter, but found I was receiving transmissions rather broken up that adjacent boats could hear clearly. A couple of months ago the set itself stopped working and I replaced it with new. All seemed to work at close range but now I realise that our range both transmitting and receiving is poor, can hardly hear the coastguard.
Investigating while sat here in Dover I find if I disconnect the junction at the foot of the mast, reception is still possible. If I push the inner connections together the reception is not surprisingly better but when I complete the connection with the outer (sheath) the reception is worse.
This suggests to me a fault in the new aerial or its masthead connection.
Is it OK to transmit with only the inner core connected or is there a possibility of damage to the set when doing this without the complete circuit?
