Playtime
My VHF radio and masthead antenna function together quite well. However, the VSWR of the antenna is greater than 2 and water was present in the coax under the deck, so I have been preparing to replace the antenna/coax.
When conducting tests of the new antenna (a Metz) with the radio before fitting to the masthead, I found that I couldn't remove the VHF 'hiss' with the squelch control. Further tests using a second VHF set and another Metz antenna (thanks SaltyJohn!) have proved that it is the radio at fault and not the new antenna/coax set up. The radio is a NASA SX35 DSC unit - about 5 years old.
Questions -
1. Why does the old antenna (VSWR >2) still work well with the radio while the new antenna (VSWR approx. 1.2) produces continuous hiss?
2. Is it possible to 'tweak' the radio so it works (properly) with the new antenna?
Questions -
