jonathankent
Now I know there has been many a thread on this in the past, so I apologise to some of you who seem the same thing time and time again, but I have been left confused from some other threads, so.......
I haven't been out sailing very much at all this season, and haven't needed the VHF at all, but today I decided to make sure that all was OK - it is a new VHF & antenna installation this year. I knew the time of the weather forecast so this was an ideal time to make sure all was receiving OK, however all is not OK /forums/images/graemlins/frown.gif.
I had my handheld to make double sure. At the time, the VHF received a very muffled and intermittent message to change to channel 23 for the forecast. However, upon changing I didn't get the forecast, but the display on the VHF was indicating it was receiving but nothing could be heard.... volume & squelch all OK /forums/images/graemlins/smile.gif. I switched on the handheld, and on the same channel received perfect reception with no interference whatsoever.... so there is a problem with the main VHF.
I have read other contradicting posts regarding testing the coax with a multimeter and resistances, voltages, etc but don't know what I should be doing to get sensible results. I will obviously be checking all the connections very thoroughly, but can someone indicate the correct method to test the connectivity within the coax??
If it makes a difference I have got one of those deck plugs aswell. I just hope it doesn't point towards the antenna connection itself - didn't trust those solderless push-in connections anyway, but I don't really want to have to go up there to try and fix it.....
All guidance is much appreciated.
