Piddy
During my holiday I found a broken connection in the VHF aerial cable. There was some contact as the central conductor was touching the pin in the connector but was broken and (I suspect) when in use creating a high resistance connection.
This may explain why my Silva radio ceased working (as in no reception or transmission) after which I fitted a Simrad RD68. Prior to renewing the connector, the reception had been OK but not spectacular. I only became aware of a problem when 'ant' started flashing on the radio whilst transmitting.
Once I had attacked the connector on deck in Cherbourg (on a windy day - very hard to get a gas soldering iron hot enough!), the reception improved markedly. On the return home from Cherbourg I spoke to Solent Coastguard with excellent clarity from just outside the harbour giving me a range of some 55miles.
I know SC has a high transmitter and that VHF is fundamentally line-of-sight but I've never had transmitting range that good and now constantly hear coast guard reports from Dover through to Brixham and down as far as St Peter Port Radio whilst in Portsmouth harbour.
Over the years occasionally atmospheric conditions allow extended range but I get this range all of the time now with the consequence of constant babble on the speaker.
My mast is about 50' - do I assume everyone with a mast this height has this kind of range and that my old (non DSC) radio was a bit tired?
Cheers
Cheers
