roggie
New Member
Advice wanted and I'm told you are all very helpful...
I've a narrowboat moored on the Slough Arm and last January joined St Pancras CC on their annual trip down the Thames to the Royal Docks - very enjoyable it was too. Didn't have a VHF radio but as in convoy didn't need one... did use a 2 way with another boat just in case. Decided to buy a VHF and book onto a course for next time - given that its usage will not be too often I went to ebay rather than a new radio... so
Purchased a second hand seafarer vhf radio and a new 1m Fibreglass Marine Radio Antenna + Cable 3db Gain 156-162Mhz Boat VHF Fixed (separately). Radio powers up from a stand alone 110a marine battery - all displays fine static coming over loud and clear... plus in the aerial with 5 metre cable and the static doesn't change in tone at all - squelch seems to work (how to tell?). Tested amps drawn when on tx in hi power and clamp meter shows around 25a. I did try (in SE London) to plug into car lighter plug but no difference. Next steps is to drive nearer to river to eliminate bad reception. I would have thought that it could receive something even with a coat hanger let alone a 1m aerial.. nothing obvious adrift internally as far as I can see. I found a copy of the manual online (badged as a GX121OS Horizon Explorer).
Any thoughts on ways forward - the seller removed this from a boat they brought and thought it worked..
Regards,
Roger
Regards,
Roger
