Baddox
My VHF is wired, via a fuse in the +ve wire, directly to a battery; this seems to be the recommended way of installing VHF’s and is how my boat was set up when I bought it.
All other electronics and electricals connect to fuse panels which are supplied by a positive and a negative heavy duty cable, each with its own isolator switch.
So far so good, except… The plotter that supplies coordinated to the VHF does so via NMEA0183 protocol where it sends the signal over a pair of wires, one is the comms wire and the other a ground (i.e. –ve) wire.
This set-up means that if I switch the heavy duty –ve isolator to “off”, all of the boat’s electronics are still connected to the –ve battery terminal, but via the thin data wire running from plotter to VHF and on to the battery. This concerns me, and I assume that mine is not the only boat to be wired like this.
I plan to disconnect the plotter –ve from the boat’s busbar and connect it directly to the same -ve supply wire that the VHF uses. This will leave the plotter and VHF on their own fuse protected but unswitched circuit.
Is this the usual set-up for a VHF/plotter pairing? Any thoughts or comments are welcome.
