vhf dsc radios
little shack
1 Mar 2010
leeds
Hi folks Just a quick one have a nasa SX 35 dsc radio this was already on a boat I've bought.Is this model quite old I seem to be having trouble broadcasting on it any dastance line of sight really.If it's an old model it may be at the end of it's life and I shall replace it.shall be trying a different airiel next week see if that makes any difference.any thought would be welcome:)
PetiteFleur
29 Feb 2008
Suffolk
I've always found that the aerial connections have to be spot on. In particular any deck connections are always suspect. Check them all and if the copper wire have gone black at the connections strip them back to clean copper. Alternatively get expensive cable which has tinned copper braid.
Billjratt
9 Sep 2004
Firth of Clyde
If it's DSC it can't be that old! (there are plenty of really old radios out there working well)
VHF is a line-of-sight (more or less) frequency band.
If it draws about 5 amps from the battery when you transmit at 25 watts, it's working.
Plevier
22 Aug 2008
Brighton
I had one of those, it gave very good range and quite good clarity. I think range faults are much more often aerial/cable than radio.
It's a re-badged MTech (or MMTech? I forget) you can easily find the manual on their site if you haven't got it.
