masthugg
New Member
I am looking for some advice or theory on VHF antennas. SInce I am fluent in microwave circuits and have a basic (but almost forgotten) theoretical understanding of antennas, I recognise that most of the stuff on antennas on boat forums is superstition, "some-guy-said", "high gain is always good", or anecdotal experience with only one antenna type.
Surveying the market, I recognise four different antenna types:
1. Steel whip (~1 m, half wavelength)
2. fibre glass pole (~1 m, half wavelength)
3. short antennas (~2-3 dm, "short "dipole")
4. 5/8-wave antennas.
Let's focus on types 1-3. There are a lot of info on half-wave dipole antennas online, but it is mostly about center-fed dipoles, and I am assuming that 1-3 are generally end-fed? Let that be the first question: Are these antennas end-fed? As far as I understand, a center-fed antenna would mean the feed line has to extend approx 90 degrees from the dipole to not interfere with radiation pattern and impedance. That's why I think most marine antennas are end-fed.
Second question: many antennas say "built-in groundplane". Silly phrasing, I would rather say that a ground plane isn't needed. But how does the mounting affect anntennas 1-3? Let's consider thre conditions: masthead (metal), pulpit (metal), fibre glass roof.
Third question: what do you recommend for a sailing vessel with a 9 m (27 ft) mast? I would like a mast mount later, but will start with pulpit mount since the boat is in the water already.
Regarding the third question, it is my impression that a short dipole and a half-wave dipole has similar properties, except that the short dipole presents a nasty impedance. To what degree is that matched and taken care of in the off-the-shelf-antennas? Since the range is anyway mostly limited by the earth's curvature, I have a hard time seeing when i would care about anything else than severe mismath or a really skewed radiation pattern.
Please feel free to answer only a fraction of the questions above
