VHF/AIS antenna with permanently mounted cable?
GTom
12 Jun 2017
Cheapest RG58 coax "of course", but I was wondering if the loss between the cable and the antenna could be mitigated with permanently mounted cable, like this one?: Shakespeare V-Tronix Stainless Steel Antenna, MD20
If there is no/very little loss with a permanently mounted cable, on my 18m run the above kit would be almost equivalent to an RG213 trough a pl-259 especially with the lack my crimping-soldering skills...
Can't recall if Salty John's Manta's were permanently mounted RG8x kits or the cable joined via a PL-259?
prv
29 Nov 2009
Southampton
Salty John’s Mantas had a PL-259. This was good because it allowed me to connect my choice of very good coax from a radio specialist. Can’t remember the designation offhand, but it was almost as thick as the plug and had complete braid coverage.
The only downside is all the French traffic I hear in the Solent ?
lw395
16 May 2007
If the antenna has a pl259 built into it, the matching network probably takes that into account so the fact the PL259 is not a perfect 50 ohms won't cause a loss.
It's not like putting a non-50ohm connection in the middle of the cable run.
Rocksteadee
25 Jul 2011
Top of the Hamble
Get that in France as well
Salty John
6 Sep 2004
UK
www.saltyjohn.co.uk
For an 18m run I'd use RG8X. It will give you about 40% loss in the cable. RG58 over that distance will lose about 65%. RG213 is even lower loss, of course, but more difficult to handle.
Contrary to some wild statements you see from time to time, insertion loss on a PL259 is minimal, a fraction of a db, as lw395 rightly says.
You can buy an 18m RG8X cable kit from Glomex with an FME connector on each end. Onto these connectors you can screw a PL259 - no soldering or crimping required. They aren't quite as easy to thread through tight spaces as bare cable ends but they're OK for most applications. Then you can connect to a decent antenna.
GTom
12 Jun 2017
Thanks, that was the information I was seeking (y)
I am leaning towards the RG8x or RG213 and get a native PL259 installed on both ends. Not sure if I got enough space between the headlining and the deck gland for the 213 (4" bend radius in case of the Belden one).
Spirit (of Glenans)
28 Mar 2017
Me; Nth County Dublin, Boat;Malahide
Adjust the squelch?
