GHA
A short tale of woe and red herrings..
Previously.....
After much gnashing of teeth getting the old cutlass bearing out - steel long keel hull, so bearing goes into a short piece of pipe against a shoulder then the pipe continues for about 3' to where the stuffing box is attached.
So, tapped the new cutlass bearing in and then tried to insert the prop shaft, gets very stiff quickly. So ever the pessimist I concluded it was catching on corrosion in the longer section of the pipe. Managed to get the new cutlass bearing back out and welded up a grinding stone on a 3' piece of rod to clean up the inside of the pipe.
Turns out the stiffness was nothing to do with that, the bearing will slide up and down the propshaft easily on it's own but once fitted the shaft become very stiff, as in barely possible turn it by hand.
Is this normal? Will it bed itself in quickly when running or do I need to ream out a tiny bit of the inside of the cutlass bearing?
It's a tight fit into the stern tube but it does go, not sure if i want to take off too much of the outside of the bearing, but maybe a bit.
Tia.
Previously.....
Tia.
